Temperature dependent wall heat flux
Old   December 6, 2018, 20:22
Default Temperature dependent wall heat flux
CA
justinc is on a distinguished road
Hello All,
I am trying to model a temperature dependent wall heat flux for a forced convection problem, and I cannot find any simple examples or help on the UDF. From my understanding I will be using DEFINE_HEAT_FLUX, but I am lost when it comes to writing the code.
The wall heat flux is a simple expression where it is directly proportional to the temperature q=aT where "a" is a constant.
Thanks in advance.
justinc is offline   Reply With Quote
Old   December 7, 2018, 00:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
All information about this topic could be found in Ansys Fluent Customization manual.
Direction for you:
from manual
DEFINE_HEAT_FLUX Description
You can use DEFINE_HEAT_FLUX to modify the heat flux at a wall. Despite the name, a DEFINE_HEAT_FLUX UDF is not the means to specify the actual heat flux entering a domain from the outside. To specify this type of heat flux, you would simply use a DEFINE_PROFILE function in conjunction with a heat flux thermal boundary condition. In contrast, a DEFINE_HEAT_FLUX UDF allows you to modify the way in which the dependence between the flux entering the domain and the wall and cell temperatures is modeled.
DEFINE_PROFILE Description
You can use DEFINE_PROFILE to define a custom boundary profile or cell zone condition that varies as a function of spatial coordinates or time.
Note that DEFINE_PROFILE allows you to modify only a single value for wall heat flux. Single values are used in the explicit source term which ANSYS Fluent does not linearize.
Simply saying for your case DEFINE_PROFILE is appropriate macro
code example from manual
UDF for specifying steady-state parabolic pressure profile boundary
profile for a turbine vane
#include "udf.h"
DEFINE_PROFILE(pressure_profile,t,i)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i) = 1.1e5 - y*y/(.0745*.0745)*0.1e5;
end_f_loop(f,t)
Once again, I recommend to you read Ansys Fluent Customization manual first
best regards
AlexanderZ is offline   Reply With Quote
Old   December 9, 2018, 16:42
CA
Hi Alexander,
Thanks for the response. I did go over the manual briefly before posting this and it seems as if the Define_Heat_Flux UDF is more fitting for a temperature dependent wall or cell heat flux.
The manual states, Define_Profile is used to "to specify the actual heat flux entering a domain from the outside." Whereas define_heat_flux UDF is used to "modify the way in which the dependence between the flux entering the domain and the wall and cell temperatures is modeled"
Attached is a picture of the geometry for clarification.
thanks,
Justin
Old   January 25, 2020, 04:36
Pacific is on a distinguished road
Hi there,
Could you find the answer?
I have faced the same problem.
All I know is that we should use Define_heat_flux for temperature dependent heat flux.
https://www.afs.enea.it/project/neptunius/docs/fluent/html/udf/node247.htm
Pacific is offline   Reply With Quote
define_heat_flux, heat, heat flux, temperature dependent, udf
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Heat flux and wall temperature divergence Mat_fr FLUENT 2 March 6, 2013 09:58
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
