Turbulence Viscosity Ratio issue in EXtended domain with Pressure Far Field BCs |
December 6, 2018, 15:48 |
MMSQ
Rep Power: 8 |
Hi everyone
I am Performing compressible flow analysis in a 30 degree sector of jet engine afterburner. Details: Steady state Flow: Compressible Turbulence Model: K,E 2 eqn with realizable BCs: Pressure inlet conditions, pressure Far field condition (at extended domain) Mesh Size: 5 Million elements (Hexa + Tetrahedral) Solver: SIMPLE Mach Number: 0.1 (used in pressure far field Boundary condition) The solution is easily converged without Extended domain (Extended domain is modeled after Converging diverging duct having pressure far field conditions). However With extended domain, there comes warning 'Turbulence Viscosity ratio limited to 1e5 in xxxx cells'. This high value of turbulence viscosity ratio is indicated only in Extended domain. It is worthwhile to mention over here that extended domain is meshed with high quality hexahedral element (element size 10 mm). The said error creates problems in convergence. All is well without including extended computational domain. Refer Attached photograph please. Please suggest the measures I should take in order to curb the issue of high turbulence viscosity in extended computational domain. Thanks in anticipation for your advices. Regards Last edited by Muneeb; December 6, 2018 at 17:21. |
Same pressure gradient but different velocity field | TurbJet | Main CFD Forum | 22 | April 28, 2018 03:35 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
