Coupling Free flow and Flow in porous media
Old   December 6, 2018, 08:52
Question Coupling Free flow and Flow in porous media
arash.mp is on a distinguished road
Hi everyone and experts,
I want to model a pipe system (Using Ansys Fluent 16.0) that consists of a main pipeline and some porous layers around the main pipeline and i want to calculate the filtration velocity and some other things in the porous domain!
i want to know that what boundary condition should i use at the interface between the FREE FLOW and POROUS LAYERS?
the flow regime in the main pipeline is Laminar and i want to use "The brinkman Equation" in porous domain!
When i simply mark on the "porous Zone" in fluent and set the boundary condition between free flow and porous domain as "INTERIOR", the results are far away from the benchmark i have for the problem! i searched the web and found that there are special Boundary Conditions for this problem!
Should i use UDF or Something else for the boundary condition?And Also does Fluent Solve Brinkman equation in porous domain or i have to write a code for that ? i appreciate if someone can help me!
And another question is that the permeability of one of the porous layers is such that when i inverse that to calculate the Viscous Resistance, the value is more than 1e+20 which is the fluent limitation! how can i fix that?
thanks for your help and sorry for long question! i wanted to make everything clear.
thanks in advance.
arash.mp is offline   Reply With Quote
brinkman, coupling 2 solvers, free flow, porous media, porous media flow
Flow through non-equilibrium porous media Jul_Z FLUENT 0 June 24, 2016 08:58
Flow through porous media: permeability issue butterfly1 Main CFD Forum 1 January 2, 2014 03:34
Flow parallel to porous media HannesVV CFX 1 June 29, 2013 08:28
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 06:52
