In .out file parameters are saved in rows not in columns
Old   December 5, 2018, 13:02
Default In .out file parameters are saved in rows not in columns
Darek
dariuszkoz is on a distinguished road
Greetings,
Im running transient turbine simulation in Ansys Fluent 19.2. I've set up various surface and volume monitors and saved them in .out files. During iteration, in every .out file i open using notepad no matter if its volume or surface monitor; flow time and parameters are ploted in ingle line/row instead in two columns.
Is there any idea to fix it, because it is hard to read it.
Regards
dariuszkoz is offline   Reply With Quote
Old   December 5, 2018, 16:33
Lucky
Probably a format reading isue. Try a different text editor. They should be in columns. Try notepad++ or wordpad or whatever
You can also try importing it into excel or matlab using the data import wizard
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
