Transient Simulation - Fluent remove my case and data
Old   December 3, 2018, 14:46
Default Transient Simulation - Fluent remove my case and data
lape95 is on a distinguished road
Hello there!
First of all sorry for my bad english.
Im doing a transient simulation and I specify Fluent to save the case and data after 15 time steps.
Yesterday, I did 90 time steps (so the program save 6 files of case and data). Today I turn on my computer to continue with my simulation but after open my last case and data file the program delete the previous file (5 files) and I only have my last simulation file.
How can I avoid this?
How can I continue my simulation without deleting the previous files?
Thank you.
lape95 is offline   Reply With Quote
Old   December 4, 2018, 03:54
Piotr Prusinski
piprus is on a distinguished road
In order to help you, you need to specify your problem little more extensively. First, are you processing your data under Windows or Linux, then via GUI or with a use of command line (TUI). With or without Workbench environment???
Regards,
Piotrek
piprus is offline   Reply With Quote
Old   December 4, 2018, 05:22
ssa
ssa_cfd is on a distinguished road
I have also had this problem. I don't know why this happens. Before closing the window, check your workbench whether everything is updated or else copy the dat files to some other folder before closing the workbench.
ssa_cfd is offline   Reply With Quote
Old   December 4, 2018, 11:49
Lucky
This is a workbench problem because there's no way Fluent by itself can do this (Fluent doesn't check for existing .cas and .dat files). Unfortunately I don't use workbench to tell you what to do to fix it.
Old   April 22, 2020, 10:20
Ricardo Moya Ch.
Ricardo Moya Ch. is on a distinguished road
Try this in Workbench:
Tools>Options>Fluent>(and uncheck "automatically delete old solutions on start of new calculations")
That probably will help!
Ricardo Moya Ch. is offline   Reply With Quote
case, data, delete, file
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Save Solution Data in a Fluent Transient Simulation asf_card FLUENT 3 September 15, 2015 22:41
Exporting data of transient simulation DURING a simulation, at user locations ? Milan2013 CFX 0 April 18, 2014 04:47
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
