Solver settings for transient analysis of flow over a 2d cylinder |
November 28, 2018, 05:28 |
Saif Ahmed
can anyone tell me what solver settings to use while performing transient analysis for flow over a 2d cylinder...
momentum and pressure..?? thanks |
November 28, 2018, 10:20 |
Lucky
Rep Power: 66 |
Defaults are good. Just figure out what time-step size you need (try to have a small Courant number). And then figure out how many iterations per time-step you need to get a converged solution every time-step. Figure out means actually go and do it! Press the run button with any settings and then learn from there. There will be some trial-and-error until you get the right settings.
How is the accuracy using VOF (pressure based solver) on supersonic flow | air_fun | Fluent Multiphase | 1 | August 25, 2021 00:59 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Analysis of flow around cylinder (2D) | katiyon | CFX | 4 | February 10, 2011 19:31 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
