November 25, 2018, 10:26 |
2D simulation in Fluent 16.0
Ujjwal Mohanty
Rep Power: 8 |
While performing a 2D simulation in Fluent 16.0, I am getting the following message:
"Update second order grid even though solver is detecting no motion for current time step" What does it mean and how does it affect my solution? |
November 26, 2018, 03:48 |
Büşra Eren
Rep Power: 8 |
Can you be more spesific about your case? For example is there any dynamic mesh or moving reference frames?
November 26, 2018, 09:54 |
#3 | |
Ujjwal Mohanty
Rep Power: 8 |
Hi, No there is no dynamic mesh. Its a simple 2D simulation problem for unsteady flow over a triangle in a fluid domain. The inlet temperature is set at 300 K and the triangle surface is set to 303 K. The top and bottom walls have free slip condition and the outlet is pressure outlet. The inlet velocity is 50m/s, density and viscosity of fluid is set to 1. |
November 26, 2018, 11:58 |
Lucky
Rep Power: 66 |
My guess was also something related to a dynamic mesh. I have no clue why you would see this message if not. Or maybe you are doing automated grid refinement?
November 26, 2018, 12:04 |
Ujjwal Mohanty
Rep Power: 8 |
Guys....I am so sorry...I did use dynamic meshing....my bad that I totally forgot about it...the simulation was running for over a day....
But is the message something that I should be worried about? |
2d simulation, fluent |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Start new Ansys Fluent Simulation automatically | Malue | Fluent UDF and Scheme Programming | 1 | October 4, 2017 01:48 |
Which Multiphase Model Should be selected in Fluent for my below described simulation | oberstar | Fluent Multiphase | 0 | September 28, 2017 12:05 |
Flux reports for transient simulation in Fluent | khaham | FLUENT | 11 | April 19, 2017 07:44 |
Simulation on fluent 14 | NAD | FLUENT | 0 | September 11, 2013 02:05 |
