November 23, 2018, 04:58 |
Moment Calculation
Büşra Eren
Rep Power: 8 |
Hello everyone. I am working on a project which i use a rocket with canted fin as a model in FLUENT. In order to find the spin rate my canted fin generates, i made some hand calculations and found a spin rate. I want to test my calculations in fluent so i meshed my rocket geometry. Rocket walls are stationary and my fluid domain is rotating with the spin rate i calculated. Moment report dhould be 0 when i enter the right spin rate.
In my case i am rotating the domain with frame motion in FLUENT but i cannot be sure of validity of my case. For moment report i enter center of pressure as reference length. Velocity calculations are relative. I use pressure based solver with PRESTO! pressure solver. Mach number is 0.3. I choose wall as moving but its 0 rad/s. Problem is residuals are always linear no change at all. I need some recommendations about rotating fluid domain to obtain correct Moment force report. |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 10:37 |
Propeller calculation | toil | CFX | 15 | May 22, 2017 05:06 |
Consistently negative moment for rolling cylinder in free surface (VoF) | Josh | STAR-CCM+ | 4 | August 25, 2014 11:34 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 05:20 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 09:19 |
