November 22, 2018, 12:33 |
Convergence problems
Rep Power: 8 |
Here is the case:
Im simulating filter press chamber. The real situation is there is one inlet and two outlets, one of which the filter membrane (porous medium). I had good convergence when setting the inlet and two outlet as boundary conditions without the porous resistance. Same happend when i set the resistance-free outlet as a wall and the porous outlet as porous jump. Both i did as a test. What can i do about it? The mesh is fairly good: 300k volumes and 0,2 minimum orthogonality |
Convergence Problems with turbulence kinetic energy | Batou | FLUENT | 0 | May 9, 2015 16:44 |
having problems with performing grid convergence study in SWFS | drdet | FloEFD, FloWorks & FloTHERM | 12 | January 22, 2015 05:44 |
Vorticity creates convergence problems? | IngmarVanDijk | FLUENT | 6 | November 12, 2014 11:50 |
NACA0012 Convergence Problems | StudentAndrew | CFX | 6 | November 21, 2005 07:49 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 20:13 |
