combustion efficiency
Old   November 20, 2018, 02:26
Default combustion efficiency
ARAVIND SRIDHARA
aravind vashista is on a distinguished road
Hii,
I am modeling a a flow involving supersonic flows with the effects of combustion. my fuel is hydrogen and air is oxidizer. i use laminar flamelet model to model reacting flows. the calculation is complete. i want to find out combustion efficiency which is (1-mass flow rate of hydrogen/ unburnt hydrogen mass flow rate). I simply get the mass flow rate of hydrogen burnt / consumed by integrating (density*Yhydrogen*V*A) (Y_hydrogen at a given streamwise location) along the leangth of the combustor. But how do i find out the unburnt hydrogen mass fraction present along the combustor length.
I thank readers for their valuable suggestions.
aravind vashista is offline   Reply With Quote
Old   November 20, 2018, 10:46
Lucky
Don't you have a progress variable in this model? The progress variable helps you distinguish between burnt/unburnt.
Old   November 21, 2018, 03:28
ARAVIND SRIDHARA
i use non-premixed laminar steady flamelet model. I dont know about progress variable, and how to set values for it
flamelet model, hydrogen combustion, non premixed combustion, supersonic.combustion
how to calculate combustion efficiency in supersonic combustion? mohamed27 FLUENT 1 June 22, 2017 06:34
efficiency of combustion safdar FLUENT 0 November 10, 2015 14:07
Question on the calculating combustion efficiency hk Main CFD Forum 0 June 1, 2007 04:46
Combustion efficiency Julie Polyakh Siemens 0 July 25, 2004 03:24
Combustion Efficiency Justin Rencher FLUENT 0 April 22, 2004 16:39
