Pressure Outlet Boundary Condition! BACK FLOW! |
November 16, 2018, 05:51 |
niewiemnic
Rep Power: 8 |
Hallo,
I do a calculation about a spray bar and there is a problem from boundary condition. It is 3D simulation and with VOF Model and Schnerr-Sauer Cavitation Model. The surface with 3 is my outlet. Initial Condition: Volume Fraction of Gas in the first cylinder is zero. And the VF is 1 in the last two cylinders. BC at 1 is velocity inlet with 3 m/s and normal to boundary BC at 2 is velocity inlet with -2,75 m/s and normal to boundary. But problem is, if I set a BC at 3 with pressure outlet, then after the spray from the middle cylinder to the third cylinder there is a back flow from 3 in the third cylinder. BC at 3 is -gauge pressure=0 -normal to boundary -turbulent options: Default -Backflow volume fraction for gas=1 Actually I think I set all options at BC 3 right, but I can not understand there is strong backflow from outside to third cylinder. Physically the spray should go out. Can anybody suggest, what is the reason? Regards, Amugae |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 19, 2018 00:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
