Reverse Osmosis Desalination
Old   November 16, 2018, 04:57
Default Reverse Osmosis Desalination
Pooriya
Pooriya93 is on a distinguished road
Hello.
I want to know is there anyone here that worked on problem of Reverse osmosis or membrane modeling with Fluent ?
problem : I have a duct, brackish water enters and upper and lower walls are membrane , so pure water passes the membrane and salt concentrates there.
membranes have an osmotic pressure related to density and water pressure more than that osmotic pressure passes the membrane.
Pooriya93 is offline   Reply With Quote
brackish, membrane, osmosis, reverse
Reverse flow and results does not converge irenefong92 STAR-CCM+ 1 February 4, 2015 16:28
Reverse rate parameters with CHEMKIN imports Kevin L FLUENT 1 June 27, 2013 05:22
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 03:19
Reverse Osmosis simulation with openFOAM Rezaa_357 OpenFOAM 1 August 11, 2012 11:17
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 11:38
