How to Maintain Zone names when Exporting ABAQUS & APDL Input files from FLUENT?
Old   November 15, 2018, 14:35
Default How to Maintain Zone names when Exporting ABAQUS & APDL Input files from FLUENT?
Andrew M
michal28 is on a distinguished road
Have been working with FLUENT and MATLAB Closely with the goal of optimizing Liquid flow paths through Aluminum bodies(i.e. Shape Optimization).
This process requires that the geometries in WB/Fluent be converted to Nodal/numerical forms for matlab processing. Up to this point I have been using Mechanical APDL INPUT & ABAQUS files exported from FLUENT for this (File>Export>Solution Data>ABAQUS).
These files provide purely text documents containing the nodal data as well as the all geometry data that can be processed in MATLAB and then re-uploaded to FLUENT for further simulation.
However when exporting these files from FLUENT I appear to lose my zone or Body Names (i.e. Fluid block_11, Aluminum Block_3,etc). Instead all zones are converted to a form of 'PID1' or 'PID45' in the text document, thus when re-uploading the geometries they lose their designated names and as all PID#. This is becoming a problem since the indexing/processing of my Fluid/Al bodies depend on their allocated name values.
How might I export these geometries in a way such that I do not use their given name values? Does anyone have experience with these file types? Or if not does anyone have a different approach to recommend?
(I have attached a visual representation of a simple 2D grid structure I am trying to work with, where each square block represents a Fluid or Al body to be determined by the optimization process)
michal28 is offline   Reply With Quote
abaqus, fluent, input file, mechanical apdl
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Tecplot Variable Names For Fluent Data Files Simon FLUENT 0 September 22, 2005 11:44
Input files for Fluent 5.4 Achilleas Tsompanos FLUENT 2 May 4, 2002 04:52
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
