What conditions should be given to a coupled wall in ansys fluent?
Old   November 14, 2018, 11:59
Default What conditions should be given to a coupled wall in ansys fluent?
cfdquery is on a distinguished road
I am trying to model a trapezoidal cavity receiver and trying to find the heat losses from it.
The inner part of the trapezium has 3 walls with air on one side and insulation on the other. In the boundary conditions dialog box of fluent solver i have given the boundary condition for the wall as heat flux condition. what should i put as the boundary condition for its shadow?
I tried giving the shadow the same conditions as the wall but it results in the area in the insulation to reach ridiculous temperatures of 5000k.
cfdquery is offline   Reply With Quote
Old   November 14, 2018, 14:37
Lucky
If you have a wall and shadow-wall then that means it's an interface. It should be a coupled wall (both of them) and neither of them should have a boundary condition.
Can you post a sketch of your domain? Is it a wall that needs a BC or is it an interface between two cell zones?
Old   November 14, 2018, 14:59
the inner walls(horizontal and incline walls) are the receivers of my geometry. They receive solar flux from mirrors. The bottom edge is a glass cover to keep the air inside. The inner region is air and on the other side is insulating material. what should the boundary condition be for incident heat flux on the receivers?
Old   November 14, 2018, 15:32
Lucky
coupled walls don't have boundary conditions, they are not boundaries. There is an option in Fluent that allows you to impose a temperature, heat flux, etc. on a coupled wall, but that is a feature for you to constrain the problem in non-physical ways.
Old   November 15, 2018, 00:00
Any idea on how i should impose the boundary conditions in my case. If i give 0 heat flux to the shadow it behaves as a adiabatic wall and if it the same heat flux conditions as the wall is given to the shadow the temperature will be very high.
ansys fluent 15, boundary conditions, heat loss, solar energy, trapezoidal
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
