Aerodynamic of Projectile
Old   November 14, 2018, 11:23
Default Aerodynamic of Projectile
Dzul Fikri Hidayatulloh
Dzul Fikri is on a distinguished road
Hello
I want to ask if the simulation I did is correct?
in this case i simulate about the exterior ballistics of projectile using ansys fluent with Spalart-Allmaras model,
i want to get the aerodynamic coefficient of the projectile,
i had done with my simulation but i still confuse with it
this is some iteration graph of my simulation
please help me for my final project hehe
and can you explain what is the convergence?
Dzul Fikri is offline   Reply With Quote
Old   November 14, 2018, 11:32
Lucky
Results look good. You can see the drag and lift is asymptotic. What is the issue you are having? You can fine tune and tweak your case by using different grids and settings, but this is a very good starting point.
Old   November 14, 2018, 11:41
Is the simulation that I did correct?
I want to find the drag value of the projectile
how to get it?
Old   November 14, 2018, 14:24
Lucky
You gave a plot of the drag... What's the issue?
aerodynamic analysis, fluent
Projectile moving inside barrel cozt Fluent UDF and Scheme Programming 3 June 11, 2019 10:32
Coefficient of Drag of a projectile for different Mach Numbers CdProjectile FLUENT 3 January 12, 2018 18:17
Aerodynamic analysis of moving projectile using CFX sathishfliegn CFX 9 August 7, 2014 07:43
Aerodynamic noise analysis with CFX famarcfd Main CFD Forum 0 December 14, 2010 08:53
Aerodynamic noise analysis with CFX famarcfd ANSYS 0 December 13, 2010 07:27
