Post-Processing Report Definitions After Re-Opening CAS file
Old   November 12, 2018, 11:46
Default Post-Processing Report Definitions After Re-Opening CAS file
Matt Ridzon
m_ridzon is on a distinguished road
You can create Report Definitions in Fluent and have them printed in the TUI, plotted as a monitor, and saved to a text file. Once you close the session, the monitor plot is gone. However, the data is in a text file in the working directory. After re-opening Fluent, is there a post-processing tool that can look at the data text file, read it, and re-create the monitor plot?
Thanks in advance!
M Ridzon
m_ridzon is offline   Reply With Quote
Old   November 12, 2018, 12:09
Lee Strobel
Time4Tea is on a distinguished road
To view report plots after you close and re-open, you need to use 'XY-plot' and load the output file that was generated. FLUENT doesn't load those files automatically.
Time4Tea is offline   Reply With Quote
Old   November 12, 2018, 19:43
Matt Ridzon
This works. However, do you know how I can have more control over the labels on the X/Y plot axes? My file contains mass flux per timestep. I don't see either of those natively available in the options of the X-Y Plot dropdown menus.
Old   November 12, 2018, 19:59
Matt Ridzon
Nevermind. I found it. There is an "Axes" button at the bottom of the X-Y Plot GUI. Therein, you can set up the axes as desired.
Thanks!
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
