How to set the BC on a wall that is under monitoring using UDF?
Old   November 12, 2018, 05:03
Default How to set the BC on a wall that is under monitoring using UDF?
Oula
Oula is on a distinguished road
Hi everyone
I'm using a special UDF to monitor the temperature on a wall. So the BC at that wall is unknown I want it as output of the simulation. I only know that at the beginning of simulation its temperature is 293 K and I want fluent to give me a data of temperature vs time of that wall. My questionis, how should I set the BC of the wall in the boundary condition panel?
what I did is setting the operating temperature to 293 K, then in Thermal Conditions> I ticked the Radiation option, I adjust the value of the external emissivity to 0.8. I could not decide about the external radiation temperature. Do I have to leave it as 293 or set it as zero. what do you think?
Any help is much appreciated
Oula is offline   Reply With Quote
Old   November 12, 2018, 11:43
Lucky
Well what is the radiation environment? If you know the external emissivity is 0.8, what is the temperature that corresponds such that the emissivity is 0.8? Did the 0.8 come from a random number generator? How did you decide on 0.8. The answer to the temperature is deeply connected to this 0.8.
LuckyTran is online now   Reply With Quote
Old   November 13, 2018, 00:56
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Do you have only radiation, no convection? emission coef depends on the surface type. It is possible to find this value relatively accurate in books.
You may describe the case you want to simulate in more details, so others could help you
best regards
AlexanderZ is offline   Reply With Quote
Old   November 19, 2018, 05:46
Oula
Hi AlexanderZ
The value of 0.8 emissivity I got it from literature. The surface is heated mainly by radiation but I want to promote convection using a specific technique. Therefore the case that I'm working on can be described as a mixture of convection and radiation.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 03:30
Radiation interface hinca CFX 15 January 26, 2014 18:11
Does the wall BC set k & e to zero? Lucy FLUENT 3 December 10, 2010 12:49
udf to set vel. = 0 at a grid point or a cell Ralf Schmidt FLUENT 0 September 22, 2006 10:45
