Rotating Surface Cleaner Analysis
Old   November 9, 2018, 05:33
Question Rotating Surface Cleaner Analysis
LK123 is on a distinguished road
I am a beginner of ANSYS fluent however i have experience in ANSYS mechanical. I have a project that i would like to use fluent for:
I am wondering if it is possible to setup a simulation of a rotating bar (at 2000 RPM) with a nozzle on either end were high pressure water (at 3000 PSI) is exiting from. This high pressure water would then hit a surface (ground) and what i am interested in seeing is the fluid flow/behavior after it has hit the surface.
Could such a model be setup and an simulation animation achieved? See attached images of water jet surface cleaners
LK123 is offline   Reply With Quote
Old   November 9, 2018, 10:02
Lucky
Doable? Maybe. But this is a really tough problem to simulate that I wouldn't take lightly. And definitely not if you have not used Fluent before.
Difficulty is you have a multiphase problem and your jets are moving around. Also the jet nozzles would be even more difficult to simulate in the same problem because they are tiny relative to the domain size.
ansys 14 cfx, fluent 14.5
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
Mid surface problem in workbench for static structure analysis mariashva ANSYS 0 March 7, 2018 04:22
Stress analysis with OpenFOAM for rotating elements Seroga OpenFOAM Programming & Development 0 March 17, 2015 17:36
2D CFD analysis of Contra rotating open rotor venkat_aero2007 FLUENT 0 January 11, 2015 13:14
Creating a Surface in FLUENT for flow analysis EKCO FLUENT 0 December 16, 2014 03:24
