which model should i use..........?
Old   November 6, 2018, 02:36
Default which model should i use..........?
sooraj546 is on a distinguished road
I am facing a difficulty in selecting which model TO should for this KIND OF PROBLEM etc.......................
Model description
The mixture of iron ore and coal particle make up a composite pellet which is considered as a porous medium. Both solid and gas phases are assumed to be continuum. The pellet shape is assumed to be spherical. these are the reactions which are happening inside the pellet.
3Fe2O3 + CO = 2Fe3O4 + CO2
Fe3O4 + CO = 3FeO + CO2
FeO + CO = Fe + CO2
CO2 + C = 2CO
eq solved include - continuity, mass balance , momentum eq that's all
rate of the first 3 reactions are given by
Ri= Si*ni*(4phi*(r^2))*kio*exp(-Ei/RT)*(Cco-(Cco2/keq))
Ri = Reaction rate Equation (mol/m3.s)
S = Shape factor of particles
r = Average particle radius (m)
ko = pre-exponential constant (m/s)
Ea = Activation Energy (J/mol)
R = Universal Gas constant. (J/ mol.K)
Cco , Cco2 = concentration of Cco , Cco2 (mol/ m3)
n = number of particles of solid reactants for reaction i in the mixture (m^-3) etc
In reality there are 2 different type of solid particle of different sizes are there which interact with gas as surface reactions,
which model should i start with................KINDLY HELP ME OUT GUYS. THANKS A LOT IN ADVANCE
sooraj546 is offline   Reply With Quote
heterogeneous reaction, particle reaction, surface reaction
kklOmega omega boundary condition at the wall - OF3.0 Artur OpenFOAM Running, Solving & CFD 1 June 17, 2016 16:42
Turbulence model choice dave13 CFX 3 December 22, 2015 08:12
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
