October 31, 2018, 12:04 |
Flow rate at the exit of the vent
Rep Power: 8 |
Hi All,
I am working on a vent. The vent is attached to a box and is designed to extract air out of the box using the venturi effect. Air is made to flow over the vent which creates a significant pressure difference between the face of the vent and the inside of the box making air to flow out. I have performed the Analysis using Fluent and trying to figure our the flow rate(mass flow rate) of the air escaping from the vent outlet. I am new to CFD and want to know how to find that out from my analysis? Please find attached a document which show few images of the setup and 3D Cad. |
Shape Optimization Problem of Mass Flow Rate | ggc1991 | SU2 Shape Design | 1 | December 1, 2016 21:24 |
refrenced pressure and refrenced temperature in Exit Corrected Mass Flow rate | behrouz | CFX | 0 | November 3, 2016 04:29 |
How to calculate phase flow rate? | sangramroy | FLUENT | 0 | January 11, 2012 14:02 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 18:57 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 03:07 |
