Simulating flow of liquid contained in a rotating cylinder with open top
Old   October 26, 2018, 02:39
Default Simulating flow of liquid contained in a rotating cylinder with open top
Djphoenix
Djphx is on a distinguished road
I am trying to simulate the transient state of a rotating cylinder which contains a liquid. The cylinder top is open to atmosphere. I want to get the free surface profile as well (the parabolic profile) when it reaches the steady state. Please help.
Thanks.
Djphx is offline   Reply With Quote
Old   October 26, 2018, 11:44
Lee Strobel
Time4Tea is on a distinguished road
Hi, I would probably look at using the VOF multiphase model to simulate the interface between the liquid and air. You may be able to use a 2D axisymmetric case with swirl, if you can apply a tangential velocity to the outer wall of the container.
Time4Tea is offline   Reply With Quote
forced vortex, rotating cylinder
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
Enabling Open Channel Flow Sub-Model in Mixture model cod213 FLUENT 0 January 10, 2017 14:40
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
