October 15, 2018, 18:36 |
Radiation model problem
Darsh Nathawani
Rep Power: 8 |
Hello everyone,
I am modeling a solar updraft tower using DO radiation model. I want to know the energy emitted by the ground. But fluent has 'volumetric emitted radiation' term which is not clear to me. As emission is a surface phenomenon, fluent doesn't have emitted radiation. Can anyone help me to understand this? Thank you. |
October 15, 2018, 18:49 |
Lucky
Rep Power: 66 |
You can find it in wall fluxes (Wall Radiative Heat Flux).
Radiation (photons moving around) is a volumetric phenomenon. You are specifically referring thermal radiation emitted by surfaces (the process of generating the photons), and not the actual motion of the energy (the radiation). Volumetric emitted radiation is like a net heat flux but for radiation (after absorption and scattering). |
do radiation model, solar chimney |
DO Model radiation fluent (Semi-transparent) problem | sasa mohamed | FLUENT | 6 | October 2, 2023 09:47 |
Diverge with Radiation model in HVAC ! | asal | FLUENT | 3 | January 27, 2023 23:36 |
Radiation model fvDoM get huge radiative heat flux | fxzf | OpenFOAM Running, Solving & CFD | 0 | April 23, 2018 11:28 |
Problem about applying scattering to fvdom radiation model !! | kane | OpenFOAM Running, Solving & CFD | 0 | February 24, 2018 06:00 |
Using radiation model for simulation of flat plate solar collector | marjanbn | FLUENT | 2 | March 15, 2015 11:27 |
