What number do i have to type about boussinesq |
October 10, 2018, 12:53 |
HakMin Lee
Rep Power: 8 |
Hi i'm student in south korea.
i'm sorry i can't enlglish very well. First question is that i want to use a boussinesq in density. but i don't know what number do i have to type in material density boussnisq. and what is operating density in operating condition? is it the density in boussnisq apporximation? So, I type the number density under the operating tempeature condition, is that right? where is typing the enumber in material boussinsq menu or operating density in operating condition? then what number do i have to type operating temperature? And I know about that thermal expansion coefficient is the reciprocal of temperature. what number do i have to type temperature in condition for reciptrocal? |
October 10, 2018, 13:55 |
Lucky
Rep Power: 66 |
Boussinesq approximation is still a constant density assumption. You need to specify the constant density and the thermal expansion coefficient. The thermal expansion coefficient is a general material property. In general, it's not always 1/T. That's why you have to also specify it. You say you know it is 1/T, but you are actually using a model in the same way that the ideal gas equations of state is simply a model for how a gas behaves (real materials don't need to follow any human-made rules).
The buoyancy term is relative to a specified reference temperature. This reference temperature is the one that you specify as the operating temperature in operating conditions. In most cases, this is the same temperature that you used to calculate the density and thermal expansion coefficient at in the material properties. If you use the Boussinesq approximation, you normally do not want to specify the operating density. Do not check this box. Last edited by LuckyTran; October 10, 2018 at 16:16. |
October 10, 2018, 23:51 |
#3 | |
HakMin Lee
Rep Power: 8 |
Thanks your reply. I know about that how can i select the number in density due to your reply. But I don't know exactly about thermal-expansion-coefficient what number i have to type. If) The operating temperature 300K -> density(boussinesq) value to be include under the same conditions(300K).. Is it right? ex) air density is 1.177m/s^2 in 300K Then what is thermal-expansion-coefficient value? Is not 1/300K? |
October 11, 2018, 13:03 |
#4 | |
Lucky
Rep Power: 66 |
If you say you have air nominally at 300K w/ a density of 1.177 then by all means input 1.177 in material properties and 300K for the operating temperature.
When you set up any model you make a million assumptions. I hope you notice and are aware that you are choosing to model your problem a certain way. |
October 11, 2018, 23:15 |
#5 | |
HakMin Lee
Rep Power: 8 |
Thank you for your reply again. The experiment condition is natural convection of air and ideal gas. So I just adopt 1/300K for thermal expansion coefficient because operating temperature is 300K. Thanks a lot! |
flunet |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
