how to make orthogonal helical coordinate system in FLUENT for helical tube case?
Old   October 10, 2018, 00:05
Smile how to make orthogonal helical coordinate system in FLUENT for helical tube case?
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear all,
I want to simulate helical pipe by using a periodic boundary condition due to less computational efforts to get fully developed profile. I only simulate one turn. Flow is laminar, fluid is water, pipe diameter 26 mm and spiral diameter 139.8 mm. Mass flow rate is 0.034 kg/s. I am using Ansys FLUENT 17. But, I find distribution pressure is bad. (see Figure Periodic Trial).
I find a paper of "torisonal and curvature effect on fluid flow in a helical annulus". They use finite difference and based on projection algorithm (see figure 1 period and helix). They also use periodic boundary condition and succeed.
I see they use an orthogonal helical coordinate system. So the velocity vector could go easily.
in FLUENT Periodic option is only in Cartesian coordinate.
How I can put my mass flow rate in the helical system in FLUENT 17?
Do you have any suggestion?
Thank you for your help
Best regards
Teguh
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   October 10, 2018, 00:15
Lucky
You can't use a helical coordinate system in Fluent. You are stuck with cartesian in 3D.
Old   October 10, 2018, 22:01
Default Use UDF
teguhtf's Avatar
teguh hady
Dear Lucky Tran,
Thank you for answering the question. I have tried to make full scale but it always stuck in the computer power. I was thinking to use periodic boundary condition as the solution. I prefer to use full scale it makes me easier to do. But, my supervisor keeps on asking me to use periodic boundary condition in FLUENT. I need to obtain a fully developed flow
Can I use UDF on PBC or other boundary condition which like PBC?
Or you have any other suggestion?
I am sorry if my question is too silly.
Thank you
Best regards
Teguh
Now Or Never!!!
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
On Coordinate system used in Fluent varghese FLUENT 9 March 22, 2002 12:16
