Reversed flow in vof model or water damping
Old   October 9, 2018, 22:53
Default Reversed flow in vof model or water damping
David712 is on a distinguished road
I am trying to simulate an example for a flow around a circle based on a stratified circumstance which also contain the air in a planar. If I use a pressure outlet for the 'out', there are reversed flow finding in the outlet even I had tried to use an udf for the pressure.
Whats more, if I use an outflow for the 'out', no reversed flow would be found but the water near the 'out' seems to rise or damp maybe.
I want to know there is a way to avoid such kinds of 'mistakes' because no matter which kind of 'mistake' do effect the flow field of the simulation.
David712 is offline   Reply With Quote
Old   October 9, 2018, 22:56
RaiderDoctor is on a distinguished road
How close is your outlet to the cylinder? Can you post some pictures of the setup and solution (preferably with a contour map and velocity vectors shown). Finally, what does your mesh look like?
RaiderDoctor is offline   Reply With Quote
Old   October 9, 2018, 23:29
http://a4.qpic.cn/psb?/a2e89427-7d40...=photolist&t=5
http://a1.qpic.cn/psb?/a2e89427-7d40...=photolist&t=5
The first picture is the wave-height for the surface flow(simulate a short time so the wave damping or rising is not obvious)
Second picture is the flow field of the circle;
Third picture is the mesh condition;
Fourth picture is the phase condition(three phase);
Old   October 9, 2018, 23:35
I can't open any of your photos. Make sure you save them in a good format (.png or .jpeg) and attach them by clicking "Manage Attachments" in the "Additional Options" section on the forum.
reversed flow, vof modeling
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Why the water is flowing along the wall by VOF model? jing113cn Fluent Multiphase 29 February 28, 2018 03:57
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
multiphase flow VOF model set up rahaman FLUENT 0 June 9, 2009 04:49
