prakash
Rep Power: 7 ![]() |
Attachment 65913WHENEVER I TRY TO OPEN THE FLUENT SETUP IT SHOW A ERROR HAND HUNG UP
IT SHOWS Build Time: Dec 2 2015 18:33:05 Build Id: 10359 Revision: 867654 Host spawning Node 0 on machine "SSI-EDU08-PC" (win64). MPI Application rank 0 exited before MPI_Init() with status -1073741511 |
Feiyu
Rep Power: 10 ![]() |
I had a similar problem, and it's been solved by the following method:
(my problem description: launch Fluent 19.2 in serial mode on Windows 10, it opens but then appears to hang or stall. With the console window showing the message of last line: "MPI Application rank 0 exited before MPI_Init() with status -". However, Fluent 19.2 can launch successfully in parallel mode both in workbench environment and launching independently) 1) Run Fluent in non-graphical mode using the following command "C:\Program Files\ansys inc\v192\fluent\ntbin\win64\fluent.exe" ^ -r19.2.0 3d -g -meshing 2) It pops up the error message reads "the code execution cannot proceed because msvcp140.dll was not found. Try reinstalling the program to fix this problem". I reinstalled a couple of times following this instruction, but it failed to work. 3) This fail is caused by operating system, and can be healed by (re)installing MS visual studio update. For my case, I reinstalled Visual C++ 2015 Redistributable Update 3, you may also try other updates. PS: see howto through https://www.youtube.com/watch?v=5XJ8_kUjVlk 4) Done! |
fluent - parallel, mpi fluent errors |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
