October 2, 2018, 08:53 |
LES Dynamic Smagorinsky Values
Oguzhan
Rep Power: 9 |
Hi everyone,
I was wondering if there is any way of checking how smagorinsky constant varies (contour etc.) within a domain when dynamic smagorinsky approach is applied? |
October 2, 2018, 10:05 |
Cees Haringa
It's an output of FLUENT (I think you can find it under turbulence in the in-fluent visualization options). You can certainly make contour plots and so on, and if you prefer to use other post-processing tools I am sure you can export it too -just may not be a default value.
October 2, 2018, 16:49 |
Oguzhan
Rep Power: 9 |
Hi Cees,
Thanks for the reply. I've looked into it but had no luck. How can we get the dynamic Cs values if they're not there by default? Thanks |
October 4, 2018, 13:57 |
Lucky
Rep Power: 66 |
It is under turbulence category. In the GUI it's called "subgrid dynamic viscosity cont"
It is not a default export variable. To export it, in the gui you would go to run calculation=> data file quantities and then check it under additional quantities.Then this quantity will be saved and can be imported by your favorite post-processor. Takes only a few button clicks and 1 minute to do. |
dynamic smagorinsky, fluent, les, smagorinsky |
Updating the turbulent schmidt number in dynamic smagorinsky model | pvpnrao | OpenFOAM Running, Solving & CFD | 3 | November 6, 2020 04:52 |
Smagorinsky,Smagorinsky-lilly or dynamic Smagorinsky model? | Jingxue Wang | OpenFOAM Running, Solving & CFD | 12 | June 15, 2020 05:17 |
Smagorinsky Problem - LES - Internal pipe flow | gu1 | OpenFOAM Running, Solving & CFD | 2 | December 29, 2017 18:54 |
Dynamic Smagorinsky LES OpenFOAM/3.0.1 | C-L | OpenFOAM Programming & Development | 6 | September 20, 2017 05:29 |
Comparing measured values with LES results | N. A. | OpenFOAM | 3 | June 27, 2011 08:05 |
