UDF compilation problem solved on Linux
Old   September 29, 2018, 01:09
Default UDF compilation problem solved on Linux
Richard
manshu is on a distinguished road
When I build the UDF on linux system by using ANSYS FLUENT 18.1, the following error occurs:
# linking to ../../src/makefile in lnamd64/3d
# linking to ../../src/user.udf in lnamd64/3d
# building library in lnamd64/3d
make[1]: Entering directory 'bftest/libudf/lnamd64/3d'
make[1]: *** No rule to make target 'example.c', needed by 'udf_names.c'.
make[1]: Target 'default' not remade because of errors.
make[1]: Leaving directory 'bftest/libudf/lnamd64/3d'
You can also see the 'log'-file in
the working directory for this compilation history
Then I copy the file 'example.c' from the folder "libudf/src" to "libudf/lnamd64/3d" and everything is OK.
manshu is offline   Reply With Quote
UDF compilation error Martin_ FLUENT 0 August 6, 2015 08:45
UDF compilation problem mystical_kaledioscope Fluent UDF and Scheme Programming 0 July 28, 2014 13:01
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
parallel udf problem in linux endlessfree Fluent UDF and Scheme Programming 0 April 13, 2010 11:19
