Reversed flow using pressure inlet and outlet? |
September 28, 2018, 15:20 |
Anonymous
The system I'm trying to model involves two immiscible liquids (one on top of the other) and an inlet and outlet at the bottom of the container, which feeds and empties, respectively, the bottom liquid. The fluid flow is driven by a pump downstream of the outlet, which creates suction and pulls the liquid from the container and recirculates it into the inlet, thus having a constant flow rate. In my simulation, I am attempting to see how the flow profile changes by changing the suction pressure.
Currently, I'm modeling the inlet and outlet as pressure inlet and outlets. For the Gauge Total Pressure on the inlet, I am inputting the hydrostatic pressure at the top of the inlet. For the Gauge Pressure on the outlet, I am inputting a lower value so as to create a pressure difference between the inlet and outlet. I am also specifying that the backflow direction is normal to the boundary and based on total pressure, with a volume fraction of 1 for the flowing liquid. The solution converges relatively well and the flow profile is generally as expected, except for the reversed flow at the inlet and outlet. To give more detail, ~ the top half of the inlet is flowing liquid into the container, while the bottom half is draining it, and at the outlet, only the bottom ~ 1/3 is actually draining liquid out, while the top 2/3 flows liquid in. I've tried changing the inlet's Gauge Total Pressure to the hydrostatic pressure at halfway the inlet and at the bottom of the inlet with the same results, making it 0, specifying a supersonic/initial gauge pressure, and nothing seems to work. Any ideas? |
pressure inlet, pressure outlet, reversed flow |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Setting both inlet and outlet with pressure boundary conditions | ahmadbakri | CFX | 0 | July 1, 2015 04:06 |
Inlet and Outlet Pressure condition for Compressible Flow in FLUENT | rsdsaurav | FLUENT | 1 | May 17, 2015 14:19 |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 08:13 |
How can I prevent reversed flow from outlet Pressure Boundaries in Fluent 6.3 ? | kalash | FLUENT | 0 | September 20, 2013 13:06 |
