gradient of strain rate magnitude for slip velocity
Old   September 27, 2018, 21:07
Default gradient of strain rate magnitude for slip velocity
Rodrigo O Orozco
totopo is on a distinguished road
Hello everyone. I am trying to write a UDF for the slip velocity in a multiphase mixture system using the macro DEFINE_VECTOR_ EXCHANGE_PROPERTY.
The formulation that I have depends on the gradient of the strain rate magnitude. As I understand it, I can retrieve the strain rate magnitude using C_STRAIN_RATE_MAG(c,t). My idea was loading said strain rate magnitude into a UDS and then getting the gradient using C_UDSI_G. I have unable to do so and gotten fatal errors in the process. I would appreciate any insight into how to go about accessing the gradient of the strain rate magnitude for use in the DEFINE_VECTOR_ EXCHANGE_PROPERTY macro.
Thanks!
totopo is offline   Reply With Quote
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
How to define strain rate and shear rate magnitude in CFD-Post? khhan0543 Fluent UDF and Scheme Programming 3 January 13, 2017 15:38
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
shear rate and strain rate Lilly FLUENT 1 August 29, 2014 01:46
Strain rate magnitude in cylindrical coordinate tinhtt FLUENT 1 July 23, 2014 03:54
