Error at host: floating point exception
Old   September 26, 2018, 13:00
Default Error at host: floating point exception
christoph irrenfried
chi86 is on a distinguished road
i have a problem when I run an UDF in paralell and write data to a file, here is the code:
DEFINE_EXECUTE_AT_END(execute_at_end)
#if !RP_HOST
    /* cell_t c; */
    face_t face;
    Thread *t;
    Domain *d;
    real position[ND_ND];
    real Avec[ND_ND];
    float x, y, z;
    float temp;
#else
    int i;
#endif
#if PARALLEL
    int size;  /* data passing variables */
    real *array;
    int pe;
#endif
#if !RP_NODE /* SERIAL or HOST */
        FILE *f_file;
        char filename[32];
        int i_curr_ts;
        snprintf(filename, sizeof(char) * 32, "ts_%d.txt", i_curr_ts);
        if ((f_file = fopen(filename, "w"))==NULL)
          Message("\n Warning: Unable to open %s for writing\n",filename);
        else
          Message("\nWriting Pressure to %s...\n",filename);
#endif
    i_curr_ts =i_curr_ts+1;
    if(time_ges>=30)
#if RP_NODE /* This is now for parallel */
        d = Get_Domain(1);
        t = Lookup_Thread(d, 11);
        size=THREAD_N_ELEMENTS_INT(t);
        array = (real *)malloc(7 * size * sizeof(real)); /* 7 rows */
        begin_f_loop(face, t)
            F_CENTROID(position, face, t);
        F_AREA(Avec, face, t);
            /* vol = C_VOLUME(c,t); */
            temp = F_T(face, t);
            x = position[0];
            y = position[1];
            z = position[2];
        array[face]= x;
        array[face+size]= y;
        array[face+size*2]= z;
        array[face+size*3]= temp;
        array[face+size*4]= Avec[0];
        array[face+size*5]= Avec[1];
        array[face+size*6]= Avec[2];
        end_f_loop(face, t)
          pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero;
        PRF_CSEND_INT(pe, &size, 1, myid);
        free(array);/* free array on nodes once data sent */
        if (I_AM_NODE_ZERO_P)
          compute_node_loop_not_zero (pe)
            PRF_CRECV_INT(pe, &size, 1, pe);
        Message("aaaaaaaaaaaaaaaa %d\n",size);
#endif /* RP_NODE */
The problem is in the passing function of the variable size but I have no idea why it crashes. Any ideas?
chi86 is offline   Reply With Quote
fluent, parallel, udf
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
[blockMesh] checkMesh Floating point exception error daniel.almeida OpenFOAM Meshing & Mesh Conversion 0 July 31, 2015 15:26
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 17:23
