solution result of any parameter at all grid points in ANSYS Fluent in data file? |
September 24, 2018, 09:49 |
Normally in ANSYS Fluent, data file or graph shows variation of a flow field parameter along axis or center line or arbitrary line. Here my question is " How to obtain/save a data file or graph in ANSYS fluent which contain solution result of any flow field parameter at all flow domain grid points?
September 24, 2018, 17:24 |
Lucky
Rep Power: 66 |
The fluent .dat file contains all the solution data at all grid points.
September 25, 2018, 14:02 |
but how to obtained a file which contain converged value of any flow field parameter of each grid point, which ca easily be imported in excel and can make a graph of it.
data file, fluent, grids points |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
