September 23, 2018, 18:55 |
Implementation of porous media in Fluent
Rohit
Rep Power: 8 |
I am modelling a flow through a porous media in fluent. But, I have data from Converge CFD files. The source.in file in Converge gives permeability coefficients in kg/m^4. In Fluent, my inputs are viscous resistance and Inertial resistance. What is the relation between the two of them? Thanks! |
September 24, 2018, 16:53 |
Lucky
Rep Power: 66 |
You need some familiarty with the Darcy-Forchheimer law which gives the pressure drop through the porous media. A lot of solvers use only the simpler Darcy's law (without the forchheimer term, but Fluent uses both).
See 7.2-4 and 7.2-2 in the Fluent manual. The mu is the viscous resistance coefficient and alpha is the permeability. The C2 is the inertial resistance coefficient (and this term is not accounted for in many solvers). I'm not familiar with CONVERGE but probably they use a mu and the permeability and have 0 for the inertial resistance. You'd better look it up and compare. |
September 24, 2018, 16:55 |
Rohit
Rep Power: 8 |
Thank you, LuckyTran
converge cfd, fluent, inertial resistance, porosity coefficients, viscous resistance |
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) | Juun | FLUENT | 1 | November 19, 2023 01:06 |
porous media in FLUENT | Natalie2210 | FLUENT | 7 | August 15, 2019 12:46 |
porous media model validation | Tensian | FLUENT | 0 | September 23, 2016 05:04 |
analysis of multiphase and porous media in ansys fluent | ahmed_khatibs | FLUENT | 0 | November 4, 2014 12:01 |
Modeling porous media with FLUENT | newcomer | FLUENT | 4 | September 26, 2013 00:08 |
