Swirl-Velocity Specification of 2-D Fan Boundary Condition |
Rep Power: 7 ![]() |
I opened a relevant thread before at the student community forums of ANSYS but did not find a closure about the subject (i.e. https://studentcommunity.ansys.com/t...ary-condition/ ). I'll appreciate any help from the cfd-online community.
I am defined a 2-D fan model using the fan boundary condition on a square surface in a 3-D simulation of a room. I am puzzled by how Fluent interprets the tangential velocity since the tangential velocity I get as a result is always less than what I input, and typically half of the constant value I input as tangential velocity (i.e. when I use values on the order of axial velocity). The results below correspond to the case with a constant tangential velocity of 1 m/s. According to the plot of tangential velocity as a function of y direction along the midline of the fan surface, the values plateaued at around 0.5 m/s outside hub (half of the input). How should I interpret this? ![]() ![]() I'll greatly appreciate your help in clarifying how Fluent uses inputs for tangential velocity in the 2-D fan boundary condition? Why don't I see the tangential velocity imposed between the hub radius and outer dimension of the boundary surface as I define? Is there a physical reasoning behind this? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Which boundary condition are you using? Fluent doesn't have a "fan boundary condition" Just post a screenshot of your boundary condition input.
Here is the screenshot of what I use.
Any help from the community would be appreciated.
yanki cob
Rep Power: 8 ![]() |
Can you check velocities slightly downstream/upstream of the fan surface?
#6 | |
2. X velocity 3. Z velocity at the velocity inlet and fan bc |
yanki cob
OK, but can you change the contour plane to another plane that is slightly downstream/upstream of the fan plane? Like, 5mm away from the fan.
Also, why do you have a velocity inlet BC? Last edited by yanki; October 3, 2018 at 08:51. Reason: added |
#8 | |
Attached are contours for 5mm upstream, fan and 5mm downstream with the same scale. Thanks |
#9 |
yanki cob
So, the max. velocity 5mm downstream is higher than max. velocity on fan plane, right?
Can you find a plane with the velocity value that you input (1m/s I guess)? Try to turn OFF the node values. |
#10 | |
I have attached the contour at 25 mm downstream of the fan, where the tangential velocity becomes 1 m/s (node values off). I guess I understand where you are going. Does the fan BC impose the tangential velocity within the first cell downstream of the fan, since the cell size is 25 mm? |
#11 | |
yanki cob
I don't know how the BC works, and couldn't find any explanation on the theory/user guide. But there might be an averaging problem, that's why I asked for turned off nodes.
As I understand, this is not a "problem" for you, you just wanted to make sure that the fan BC works the way it intended to. Quote:
3-d simulation, fan boundary condition, swirl, tangential velocity |
The method on dealing with velocity in static pressure outlet boundary condition | mona.li | CFX | 2 | September 30, 2017 01:33 |
Velocity jump boundary condition | ASofia | OpenFOAM Programming & Development | 0 | July 14, 2016 09:01 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
