Pressure-swirl atomiter: downstream density
Old   September 17, 2018, 11:29
Default Pressure-swirl atomiter: downstream density
Daniele Obiso
danobis is on a distinguished road
Hello everyone,
I am simulating a diesel spray combustion of a furnace. The setup I am using includes:
  • Pressure-swirl atomizer
  • Non-premixed combustion, PDF
The setup works well in steady state. If I include a solid region in the model, so basically with a CHT approach, I got the following message:
Pressure-swirl atomizer injector:
Pressure 600000 less than down-stream pressure -1, or
Invalid downstream density -1
Skipping injection
Did someone of the community encounter this warning? Because of that the injection is skipped, so the simulation continues just with the fluid flow.
I am in contact with ANSYS, but it would be nice if someone of you had this in the past and could have some hints.
Looking at pressure and density fields, nothing strange is to be remarked! So my basic question is: where are this down-stream pressure and density referred?
Thanks in advance,
Daniele
danobis is offline   Reply With Quote
cht, injection pressure, lisa model, pressure swirl atomizer, spray atomization
Density and pressure correlation shk12345 FLUENT 6 January 3, 2012 10:14
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Modeling pressure swirl nozzle - need help! Albert FLUENT 0 April 15, 2007 18:47
Warning 097- AB Siemens 6 November 15, 2004 05:41
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
