Weiqiang Liu
Rep Power: 9 ![]() |
Hi all,
I have two thermo data file at hand. one is from GRI 3.0 thermo data and the other is from n-dodecane thermo developed by Hai Wang. the former has 14 fitting coefficients and the latter has 15 fitting coefficients. I looked up chemkin user manual and found that normally there are 7 coefficients for the upper temperature range and 7 coefficients for the lower temperature range and the total number of coefficients is 14. So what is the problem with 15 coefficients? thanks. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
I have heard tales of 15 coefficient thermo formulations used for by other non-chemkin mechanisms. These usually come with instructions that say "delete coefficient 15 because it is not used by chemkin." Maybe that's what you have come across.
Weiqiang Liu
OK, so you think I should delete coefficient 15 so that the thermo data can be imported into fluent as chemkin format thermo data?
Lucky
I think you should look carefully at what thermo.dat you actually have because it's clearly not a chemkin one. I don't know Hai Wang and I have no clue what you have. For all I know, the 15th coefficient could be their bank account number. And I have no clue what the mapping is from one to the other, maybe you need to delete the 1st coefficient, or the 4th. No clue.
#5 | |
Weiqiang Liu
chemkin thermo |
problem with exporting data to Tecplot | v.jab | OpenFOAM Post-Processing | 2 | January 11, 2017 08:56 |
[OpenFOAM] saving data in paraview | aylalisa | ParaView | 3 | May 31, 2014 11:38 |
[General] Warping Cells by Vectors? | ronwelty | ParaView | 10 | April 29, 2014 05:52 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
