August 31, 2018, 12:36 |
Meshing of a formula student racing car
Taylor
Rep Power: 8 |
Hello everyone,
I am currentrly working on a project involving the meshing of a formula student race car ... but I do have issues with the mesh It doesn't converge each time and when it does I have the following messages every iterration : "turbulent viscosity limited to viscosity ratio of 1e05" "reversed flow in the outlet" Here are the settings I use (from https://www.youtube.com/watch?v=_4C7...ox3V0ib82t4drw) : Right click on model -> Scoped sizing : - BOI-far (around the whole car) : Min 1, Max 500, G-R 1.2, name : boi-far, Min 1, Max 50, G-R 1.2, selection : BOI-far. - BOI-near (around the front/rear wings and the wheels): Min 1, Max 500, G-R 1.2, name : boi-near, Min 1, Max 10, G-R 1.2, selection : BOI-near. - Wing-curvature : Min 1, Max 500, G-R 1.2, name : wing-curv, type : curvature, Min 1, Max 10, G-R 1.2, normal angle 9, scoped to : face zone, selection : wing. - Wing-proximity : Min 1, Max 500, G-R 1.2, name : wing-prox, type : proximity , Min 1, Max 4, G-R 1.2, cells per gap : 3, scoped to : edge zone, selection : wing. - Rod-curvature (around suspensions) : Min 1, Max 500, G-R 1.2, name : rod-curv, type : curvature, Min 1, Max 4, G-R 1.2, normal angle 9, scoped to : face zone, selection : rods. - Wheel-curvature : Min 1, Max 500, G-R 1.2, name : wheel-curv, type : curvature, Min 15, Max 20, G-R 1.2, normal angle 9, scoped to : face zone, selection : wheel. - Stand-curv (between wheels and road) : Min 1, Max 500, G-R 1.2, name : stand-curv, type : curvature, Min 1, Max 4, G-R 1.2, normal angle : 9, scoped to : face zone, selection : stand. - Chassis : Min 1, Max 500, G-R 1.2, name : chassis-curv, type : curvature, Min 10, Max 50, G-R 1.2, normal angle 9, scoped to : face zone, selection : enclosure. I then improve my surface mesh using Diagnostics->connectivity and quality. I then mesh the enclosure with tet using the default settings and adding the option Grow prisms : scoped, name : wing-prism, offset method : last ratio, F-H : 0.02, number of layers : 10, last % : 20, Grow on : selected face zone -> wing. I set the boundary conditions (moving walls, rotating wheels ...) use Viscous model : k-omega, SST, curvature correction, production limiter. I choose a coupled solver and run calculations. Do you have better propositions on the meshing procedure and on the parameters I should use ? Everything seems to work fine in the video but fails when applied to my particular case... Thanks a lot in advance for your help, Scientifix |
August 31, 2018, 13:32 |
Lucky
Rep Power: 66 |
Turbulent viscosity limited and reversed flow doesn't necessarily mean the mesh is bad, could just be a bad initialization and not running long enough to converge to the right solution.
My recommendation, start over. Mesh a plain box and run it until you get more familiar with the software(s) being used. |
[ICEM] Meshing of whole car | Divyanshu | ANSYS Meshing & Geometry | 1 | February 9, 2014 23:56 |
Some questions about making a car racing simulation | yossir4 | FLUENT | 0 | November 11, 2013 01:58 |
Meshing 3D Model of Racing Car | T1M | Main CFD Forum | 7 | April 13, 2012 16:30 |
modeling exterior aero for Formula Student Car | FSAE_student | STAR-CCM+ | 5 | November 11, 2011 13:08 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
