Monitoring/writing a single parameter from UDF. |
August 31, 2018, 09:33 |
nm
Rep Power: 13 |
what is the best way to write an output parameter (calculated in a udf) as a monitor? It is not a variable like temperature or pressure that has to be stored at each cell location. Just something similar to global maxima of temperature (not the same). So using c_udmi seems inefficient. What would be the best way? |
August 31, 2018, 10:21 |
nm
Rep Power: 13 |
Can you also tell me how to access this (to plot or monitor) from the fluent GUI? I am not sure I understand.
August 31, 2018, 10:36 |
#5 | |
nm
Rep Power: 13 |
Yes, real time plotting would help me tune the relaxation factors in the UDF quickly. |
September 2, 2018, 21:52 |
Alexander
Rep Power: 34 |
you may write variable value to output console using Message macro
best regards |
fluent, udf |
Scheme (or UDF) load Parameter value | HHOS | FLUENT | 0 | September 4, 2017 04:25 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 09:39 |
Single v.s. double precision | Confused | CFX | 15 | November 10, 2016 04:42 |
UDF for linear PTT model implementation | dpitz | Fluent UDF and Scheme Programming | 1 | February 4, 2011 10:08 |
