steady vs transient fluid flow behaviour
Old   August 30, 2018, 07:07
Post steady vs transient fluid flow behaviour
Vkt
vkt1993 is on a distinguished road
I am doing my project on odor source localization. I am doing the simulation using ansys fluent 19.1 software to understand the behavior of CO2 gas.
1st I performed simulation in steady state and then in the transient state.
but I am not able to understand the reason why flow behavior in both cases is different. I want to understand it mathematically. I am attaching the images of both.
vkt1993 is offline   Reply With Quote
Old   August 30, 2018, 22:00
blackmask will become famous soon enough
The flow in transient simulation might be not well established. The height of your domain is estimated as 40m, and the upward convection velocity is about 4m/s, which result in a flow pass through time to be 10s. You need to simulate for more than 10s. Another question is, why do not you start transient analysis based on the fields from steady analysis? Note that if you are able to obtain a converged result from steady analysis and it is physically sounding, there is no need to do a transient simulation.
blackmask is offline   Reply With Quote
Old   August 31, 2018, 11:46
Vkt
thanks for your reply... actually I am using ANSYS software first time and currently, my aim is to trace the trajectory of the plume of different gases in the different environment as well as in different boundary conditions.
so I want to know am I going in the right direction?
ansys fluent 19.1, cfd, odor source localization
Steady/ Transient Calculations Saidul ANSYS 0 May 4, 2015 23:04
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Flow Across Tube Banks - Transient vs Steady State HeatTransferFan CFX 11 September 28, 2012 15:21
Laminar gas flow under slight suction - transient works but not steady audrey CFX 1 September 8, 2011 20:43
