Simulation Of Micro Heat Pipe
View Poll Results: Is predefined Lee model with VOF appropriate for simulation of micro heat pipe
Yes 0 0%
No 0 0%
Not Sure 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old   August 29, 2018, 13:27
Smile Simulation Of Micro Heat Pipe
Akashdeep Gangrade
gangradeakash is on a distinguished road
Hello friends
I am trying to simulate the micro heat pipe in fluent, basically it is a heat pipe with condensation occurring at one end evaporation at other end and capillary forces due to change in curvature of vapour-liquid interface moves the fluid at corners from condenser section to evaporator and vapour move in a central region
I have taken a 1000 micrometre pipe with 300mm of both evaporation and condenser section from both end and leaving 400 in between as adiabatic section cross-section of 100 X 100 micrometre
Boundary Conditions- 10KW/m^2 @ evaporator -10KW/m^2
also in another case, i have given 363K at evaporator and 300K at a condenser
I all case these boundary conditions are given at walls
Methodology
Primary Fluid - water-vapour
Secondary Fluid-water-liquid
I patched water in the evaporator section at the beginning
Piso, momentum second order upwind, volume fraction- modified HRIC
The problem I am facing while a simulation is that the liquid is evaporating in evaporation section but not condensing in condenser section i am using the VOF model with default condensation and evaporation model in fluent 19.0
I am new into all this any type of help is deeply appreciated, if anyone can share the fluent case of evaporation/condensation process it will be of great help
Regards &Thankyou
akashgangrade64@gmail.com
http://www.image-maps.com/map_image.php
gangradeakash is offline   Reply With Quote
evaporation-condensation, fluent, heat exchange, heat pipe, micro channel
Fluent/icepak UDF for heat pipe simulation debuger Fluent UDF and Scheme Programming 0 July 19, 2017 13:05
Heat pipe simulation in CFX abymathew CFX 1 November 3, 2015 18:31
New guy trying to solve his first simple Heat Transfer simulation. BhaluBear OpenFOAM 2 August 12, 2014 13:54
High values of heat transfer coefficient for laminar flow in pipe Allankey CFX 2 May 28, 2014 13:44
simulation of heat pipe (evaporation part) DanielLai FLUENT 0 November 5, 2011 11:26
