calculation of mass flow rate from the inner part of a vertical cylinder in natural
Old   August 24, 2018, 08:56
Default calculation of mass flow rate from the inner part of a vertical cylinder in natural
manoj kumar dash
manoj kumar dash is on a distinguished road
Dear all
I am doing numerical simulation of fluid flow and heat transfer from a hollow vertical cylinder in fluent. I want to find out mass flow rate through the pipe. I am performing 2-D axisymmetric case. i draw a line in the cylinder domain, but i am getting mass flow rate in negative. Can anybody kindly suggest me how to calculate mass flow rate correctly and what is wrong in my approach.
Thanking you all in advance
manoj kumar dash is offline   Reply With Quote
Old   August 24, 2018, 09:02
subhankar das
subhankarnits is on a distinguished road
R u calculating mass flow rate at outlet?
subhankarnits is offline   Reply With Quote
Old   August 24, 2018, 09:05
manoj kumar dash
No as i am performing the problem in steady state the mass flow rate i expected to be same through out the inner portion of pipe as mean velocity will be same every where. I want to know why it is giving a negative value.
Old   August 24, 2018, 09:55
Lucky
Negative means it's going the opposite direction as the normal vector when we're talking about surfaces. With lines, the outward normal vector follows the right hand rule.
Try drawing your line in the reverse and you should get a positive mass flow.
Old   August 24, 2018, 09:58
subhankar das
Can you tell me in brief. I don't understand
Old   August 24, 2018, 11:57
manoj kumar dash
Dear sire thank you very much. I have changed the y co-ordinate(reverse the position of two point), but i am getting the same negative value. Can you please tell me what you have done , had i done the same thing or am i not able to get what you told. Thanking you very much .
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
Specify mass flow rate for periodic boundary conditions in channel flow lion1990 OpenFOAM Running, Solving & CFD 1 July 9, 2018 18:46
Mass flow rate calculation sahmed OpenFOAM Running, Solving & CFD 1 June 1, 2016 13:53
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 08:55
mass flow rate calculation Ahmed CFX 7 June 20, 2008 06:55
