Error: cell is missing face
Old   August 20, 2018, 07:45
Default Error: cell is missing face
Yahia
Yahia Shannan is on a distinguished road
Hello everybody,
I'm meshing a half model of a serpentine (offset) duct in ICEM CFD. Initial geometry had been created in SolidWorks and then imported to ICEM CFD. The created hexahedral mesh is of a good quality and neither Error nor Possible Problem was detected during check/fix. The only problem that I face is while I import the mesh into fluent. An error of "cell is missing face" is prompted as in the attached figure. Importing any mesh rather than hexa mesh (Blocking) is going smoothly and no error prompted.
Any suggestion will be highly appreciated. Please don't hesitate to ask for any additional illustrating figures.
Best regards
Yahia
Attachment 65164
Attachment 65165
Attachment 65166
Yahia Shannan is offline   Reply With Quote
Old   August 20, 2018, 08:43
blackmask will become famous soon enough
The attachment can not be downloaded. Please mark sure that all of geometric boundary surfaces are associated with block faces.
blackmask is offline   Reply With Quote
Old   August 25, 2018, 07:26
Yahia
Meshing Half Model.pdf
Half Model.pdf
HM error.pdf
Dear Blackmask,
For more clarification, I'm gonna state all the steps followed during meshing as follow:
1. The geometry was imported to ICEM CFD in .igs extension.
2. Parts were created as Inlet, Outlet, Wall and Symmetry.
3. Material point was created as FLUID.
4. Topology was built using filtering angles that less than 30 degree.
5. Block was initialized and split.
6. Since the duct is offset, "extrusion along a curve" method was utilized in order to block the whole duct.
7. Vertices, edges, faces were associated to points, curves and surfaces respectively.
8. Mesh size was set on the surfaces and pre-mesh was converted to unstructured mesh.
9. Output to fluent and BC's were specified.
10. Mesh file was written to Fluent.
However while importing to fluent still error of cell is missing face prompted.
Best regards
Old   August 27, 2018, 02:32
Thank you for your detailed explanation. I see no problem if everything is done as you said. However, please check which surface is located near (-50.88, 165.6, -71.2) and make sure that this surface is associated with block faces. Also, make sure that ICEMCFD does not issue any warning when you export unstructured FLUENT mesh.
Old   August 29, 2018, 05:36
Yahia
Dear blackmask,
I just want to inform you that importing the mesh is done . I just tried to associate each and every single face to the geometry surfaces after O-grid generation. It seems to me that generating the O-grid will result in non-associating faces that have to be associated after.
I really appreciate your cooperation. Thanks indeed.
Best regards.
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent Ayo_gboyega ANSYS Meshing & Geometry 1 June 17, 2018 04:02
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
