MRF approach for CSTR
Old   August 18, 2018, 19:17
Default MRF approach for CSTR
Jerónimo Guarco
jeronimoguarco is on a distinguished road
I'm modelling a CSTR (see attached image) through the MRF approach. For this purpose I created a cylindrical volume around the impeller to which I assign an angular speed of 100 rpm. The rest of the reactor is left as static and there are no baffles.
What I'm most concerned about it's the solution I get, which I also uploaded as a picture here. You can observe there is a big change in the velocity profiles from the static and the rotating frames and there is no smooth transition. Is this correct?. When I plot this in "Stn Frame" I get another plot which is what I would expect (also attached).
Another concern of mine are some surfaces and regions (wall-13, wall-14 and interior-8) which I'm not sure what they are. I attached a picture in which I show them in FLUENT. I try to display them and they appear to be nothing. All other surfaces I displayed corresponded correctly. What do you think these are and are they a problem?
Thanks in advance!
Jerónimo
jeronimoguarco is offline   Reply With Quote
cstr, mrf, rotating, stirred, stn frame
MRF and topoSet problem- Rotating volume doesn't rotate andreas0209@hotmail.com OpenFOAM 1 April 4, 2021 14:35
MRF setup andreas0209@hotmail.com OpenFOAM Pre-Processing 1 August 6, 2015 10:36
[DesignModeler] Modelling mixing tank using MRF approach Natali ANSYS Meshing & Geometry 0 March 17, 2015 07:26
Unsteady solver + MRF (=frozen rotor) approach xxxx Main CFD Forum 7 December 2, 2014 10:34
Unsteady solver + MRF (=frozen rotor) approach xxxx OpenFOAM Running, Solving & CFD 0 November 28, 2014 16:45
