August 15, 2018, 05:49 |
Different Results using CFX and Fluent
i have a problem with the result i am gaining out of the two solvers from CFX and Fluent. At first i used CFX to simulate a simple thermal driven Ventilation through a window. Now i have to use Fluent, because of a model i want to use. So at the moment i try to simulate the same as in CFX, to validate this simulation and after that i add another model, but i get different results out of it. I tried so many things, like changing the turbulence models or using different Boundary conditions. But when i setup the Simulation with the exact parameters in Fluent, the magnitude of the value i observe is higher than in CFX. Is there any hidden setting, that i did not already changed and obeserved? Would be glad if someone could give me any advice. Thanks |
results, room, thermal, ventilation, window |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
Transfer Fluent Results to CFX | yanqoue | FLUENT | 0 | September 9, 2016 09:18 |
CFX results as initial value for FLUENT 6.3 | mohammad | FLUENT | 1 | January 23, 2012 06:39 |
CFX or Fluent for Turbo machinery ? | Far | FLUENT | 3 | May 27, 2011 03:02 |
CFX vs. Fluent Results | n.sharifi | CFX | 8 | November 3, 2010 16:40 |
