The resolution of the fluent interface is too high
Old   August 15, 2018, 06:33
Default The resolution of the fluent interface is too high
Aurelio
aurelio is on a distinguished road
Hi guys, I have a Macbook pro 2017 and I just installed ANSYS Fluent 18.2 on Windows 10 after partitioning my HD with Bootcamp.
The installation process went all good, but in the moment I open Fluent the resolution of the graphic interface is too high! Pratically all the options and everything appear too small, even though the resolution of my Windows 10 is the right one. It seems that the problem is only related to Fluent and I was wondering if there's an option button to set the right resolution (I didn't found it). I tried everything to set the right resolution but witout success. I risk to become blind !
Does enyone knows the solution to my problem or had the same problem of me?
I attach you the screenshot as to give you an idea of the problem.
Thank you in advance
aurelio is offline   Reply With Quote
interface, options, resolution, settings
mesh interface in Fluent AvaShahrokhi FLUENT 10 December 25, 2020 08:58
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
default formula for blurring interface in fluent? hospital0968 Fluent Multiphase 2 May 10, 2017 08:13
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
