UDF to store initial velocity components in UDM |
August 15, 2018, 06:06 |
UDF to store initial velocity components in UDM Segmentation error
Simon
As the title says I'm trying to write a UDF to store the initial velocity components from a solution in a UDM variable (I need these intial velocities for a VG source term model I'm trying to implement). To do this I'm trying to use DEFINE_ON_DEMAND. Currently I'm having trouble interpreting the UDF and receiving a segmentation error. Can anyone shed some light on why this might be happening? I'm basing my code on the post here (Udm value on the walls). I have already allocated 8 UDM locations and am running in serial, though would like to convert to parallel if I can get it working. Code: #include "udf.h" int ID1 = 13; int ID2 = 14; int ID3 = 15; DEFINE_ON_DEMAND(allocate_vel_initial) { Domain *d; Thread *tc; Thread *tf; Thread *tA; Thread *tB; Thread *tC; cell_t c; face_t f; d = Get_Domain(1); tA = Lookup_Thread(d,ID1); tB = Lookup_Thread(d,ID2); tC = Lookup_Thread(d,ID3); /* Loop through all the cell threads in the domain */ thread_loop_c(tc,d) { /* Loop through the cells in each cell thread */ begin_c_loop(c,tc) { C_UDMI(c,tc,0) = 1; C_UDMI(c,tc,1) = 2; C_UDMI(c,tc,2) = 3; C_UDMI(c,tc,3) = 4; } end_c_loop(c,tc) } /* loops over all face threads in a domain*/ thread_loop_f(tf,d) if (tf == tA) continue; if (tf == tB) continue; if (tf == tC) continue; { tc = THREAD_T0(tf); /*unique cell thread next to boundary face thread*/ /* Loop over faces in a face thread to get the information stored on faces. */ begin_f_loop(f,tf) { c = F_C0(f,tf); /*index of cell next to given face on boundary*/ F_UDMI(c,tf,4) = 5; F_UDMI(c,tf,5) = 6; F_UDMI(c,tf,6) = 7; F_UDMI(c,tf,7) = 8; } end_f_loop(f,tc) } } Error: Error: received a fatal signal (Segmentation fault) Error object: #f Last edited by simonmcintyre; August 15, 2018 at 11:10. |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 18:36 |
Foam::error::printStack after large bounding epsilon events | StoneCFD727 | OpenFOAM Running, Solving & CFD | 1 | January 1, 2018 18:04 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
