conjugate analysis for nozzle
Old   August 8, 2018, 07:53
Question conjugate analysis for nozzle
Sai Krishna
Sai Krishna is on a distinguished road
i have some doubts regrading conjugate analysis.
i am trying to simulate an experiment, in which outside temperature is measured because of the hot gas flow in the simple C&D nozzle.
i am taking an axi-symmetric case of the nozzle and used icem cfd for meshing the model, with solid and fluid domains for the fluid and thickness of the nozzle.
i have also tried using the one sided wall and giving thickness to the wall in fluent boundary conditions.
its a transient analysis, the materials are air and aluminium and with the available inputs i am giving mass flow inlet, and the pressure outlet (exhaust to atmosphere.)
but none of them are giving results matching with experiment results. i am not getting where i am getting wrong.
help will be greatly appreciated.
thank you.
Sai Krishna is offline   Reply With Quote
conjugate analysis, nozzle analysis
Conjugate Heat Transfer Analysis Problem redwanamit034 FLUENT 1 June 17, 2015 00:39
[ICEM] generating mesh in icem cfd for conjugate analysis sut ANSYS Meshing & Geometry 3 October 22, 2012 06:31
Please help me with conjugate heat transfer analysis pilsken FLUENT 0 April 21, 2010 09:24
2D Conjugate thermal analysis Prasad Main CFD Forum 0 February 11, 2009 21:34
Conjugate Heat Transfer analysis using FLUENT Ravi Kiran FLUENT 0 February 16, 2006 05:39
