Creep Flow Modeling
Old   August 8, 2018, 00:09
Default Creep Flow Modeling
Dustin Ray
dray19 is on a distinguished road
I am looking the fluid dynamics in a square microchannel for 0.1<=Re<=1000. This involves determining the hydrodynamic entrance length and the friction factor for both in the developing and developed regions.
I have conducted a mesh independent study for Re>100 and validated the results with previous researchers experimental and analytical work
When I did the mesh independent study (7 meshes) for Re=0.1,1,10, inlet pressure increases by 2% (~0.01, 0.1, 1 Pa respectively) with each mesh refinement. The other parameters (velocity, entrance length) seem to constant expect entrance length changed in last few meshes. I increased the number of elements in each direction by 25% to give approximately 2x the number of elements.
Should I keep increasing the mesh? Am I missing something else? I have read (forums) that fluent should be able to handle creep flow but maybe it can't.
Any help is greatly appreciated.
Attached are the results for Re=0.1 mesh study
Model Information:
Microchannel: 100um x 100um x 210um
Model Domain: 50um x 50um x 210um (symmetry applied)
CFD: Ansys Fluent 19.1
Double Precision
Solver - Pressure-Based, Steady State
Model – Laminar
Residual – 10E-6: Continuity, Velocity in X,Y,Z Direction
Methods:
Scheme: SIMPLE
Spatial Discretization
Gradient: Least Squares Cell Based
Pressure: Second Order
Momentum: Second Order Upwind
dray19 is offline   Reply With Quote
creeping flow, fluent, micro channel
Viscoelastic flow modeling in rotorstator system vulda OpenFOAM Running, Solving & CFD 4 December 25, 2017 04:01
Multiphase flow (Eulerian) modeling Umesh FLUENT 5 December 29, 2014 11:06
Modeling the mixing of air and kerosene in a flow channel StefanG CFX 3 June 11, 2012 21:21
mold flow modeling Pei Hsieh Main CFD Forum 0 May 4, 2005 11:08
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
