Import multiple CGNS files for overset into Ansys-Fluent |
August 7, 2018, 14:00 |
Rep Power: 8 |
Hello everyone,
I have 4 .cgns files and I am trying to do an overset mesh with them. I have been trying without success to import the files into Fluent by importing the CGNS files, but it only accept one file at the time. I also try the Setting Up Domain/Zones/Append. However it only accept .uns or .mesh files not .cgns. Any suggestions?. Thanks for your help . |
August 7, 2018, 14:38 |
Lucky
Rep Power: 66 |
Read each CGNS into it's own case file and save it. Then append. Is that doable?
August 8, 2018, 02:09 |
Rep Power: 8 |
Thank you very much Luckytran, that works perfectly. I saved each case .cas and then append.
cgns, overset fluent |
[GAMBIT] Can I import multiple gambit mesh files to fluent? | swtbkim | ANSYS Meshing & Geometry | 2 | September 22, 2015 04:07 |
import to Ansys Fluent Design modeler shows 4141 parts and bodies | samnath | FLUENT | 5 | April 6, 2015 02:22 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
CGNS import in fluent - periodic boundaries. | Bjarne Børresen | FLUENT | 2 | April 25, 2013 11:12 |
import fluent cas.gz files | bramv101 | STAR-CCM+ | 0 | September 23, 2009 08:28 |
