Rep Power: 8 ![]() |
Hey guys,
I am simulating a supersonic flow (combustion with laval nozzle). As inlet I choose a massflow-inlet, which is used by 1) the Gaseous Oxygen and 2) a DPM Surface Injection of the liquid Kerosene droplets. Question 1: When i choose the density based solver, and look at the reference values at the inlet, it shows me an Inlet Temperature of 160 K, but my Inlet Boundary condition of the Mass-Flow Inlet I typed in is 300 K. If I choose the pressure-based solver the reference-value of this inlet changes to 298 K and is realistic. My Inlet Conditions are: Mass-Flow rate: 0.02 kg/s Supersonic/ Inital Gauge pressure: 1e6 Pa Oxygen Fraction: 100% (1) Gas model: Ideal Gas Question 2: If I choose the pressure based solver, everything works very well. Droplet evaporation, Eddy-dissipation combustion, resulting chamber pressure, etc. But as soon as the flow gets supersonic, it gets a little bit off in terms of the mach diamonds and the flow behaviour of the exhaust plume as seen in the real process. The Mach number is around 3 at maximum. Do you recommend any specific settings for this supersonic compressible flow for the pressure-based solver? Or can you give me suggestions to get the density-based solver running for this case, because the above problem (Question 1) forces me to choose the pressure-based solver. Best regards, Max ![]() This picture shows the pressure-based solver results regarding the temperature. In reality it has like 7-9 mach diamonds, in this case just 2-3. I read that other studies use the density based solver, but because of Question 1 I am not able to run it with this one. Last edited by rap7or; August 2, 2018 at 14:12. |
Taiwan,new north city
Rep Power: 9 ![]() |
your work is amazing. can you explain how did you see the reference temperature value at inlet. did you check reference value in CFD post or fluent solver? Thanks... |
i am sure you might have checked all the possible way. I think it is better to ask ANSYS or your vendor for this issue. Because it is very strange. I never face this kind of problem. Thanks.. |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Density or Pressure based solver | Achu | FLUENT | 1 | April 27, 2018 04:34 |
New solver with temperature-dependent density based on simpleFoam? | fanta | OpenFOAM Programming & Development | 0 | December 5, 2017 03:40 |
Density based solver with cnst density! | p_agoodboy | FLUENT | 0 | November 8, 2010 22:18 |
Regarding Density based solver | Eswar | Main CFD Forum | 2 | June 6, 2007 11:00 |
